HowTo: MOC Tutorials
Hmmm, i might try to do a how to of the complicated parts of my self moc here. Its mostly small technic pieces mushed together to create a solid piece. It looks really good tho.
And this is without armor.
If you want a how to then i want atleast 10 people asking for it.
I have a very bad memory so i might put it back together wrong :joy:
Oh yea, this is not the current version. The arms have changed a bit.
You could always take pictures as you’re taking it apart, and just follow your own instructions on how to put it back together again.
May i use that head design?
Alright this is an arm build I used in a previous MOC topic of mine and its kinda easy to build. It’s better used for bigger MOCs but uh… I don’t really care on what you do with them XD.
I’m just gonna do one arm cause they’re just the same build and I’m kinda lazy.
Ya need these.
(You squeeze them together and make sure the axle is sticking out on both sides)
(Comnect the part I made earlier like this)
(Then flip it over and add this piece)
(Now bend it at a 90 degree angle and add those 2 pins)
(Now add this technic piece and flip it over so that the technic parts are pointing to your right)
(Now push that part in and do the same steps to make another arm)
(Connect the other arm on)
(Then add a CCBS torso if you want, it’s optional. Then just add some armour)
And you done son!
you could um
semd it to someone on Discord and they could fix it for you
maybe
Well, hey, man, if you’re offering…
Im making pohatu and gali using lalam24 build, but don’t know where to start, any suggestions?
@Samtastictogo has instructions in above posts.
I already got them but I need a build specifically for gali and pohatu
Here’s a torso build I created yesterday for anyone who wants to… I dunno.
Here are the pieces you’ll need. None of the colors need to be like they are here. Also, the weapon pieces aren’t used.
<img src="/uploads/db5640/original/3X/5/3/539bfcc016c31993dc8c3ee8caccbab882383413.JPG" width=“666"src=”/uploads/db5640/original/3X/a/f/afcd8b1a04296685e44039d166c1f74db8da3016.JPG" width=“666” height=“500”>
Now flip it over.
The frame is done! Now you can add what you want to make it your own!
You might be wondering how I put on that Hordika chestplate.
Now just attach it to the CCBS chestpiece!
Thats if for now!
~Levva
Doo-Head?
so… were you on a phone or what?
Anyone have a frame for an upper leg that could connect to this?
Thathe leg really reminds me of junkrat’s prosthetic leg in overwatch
PS4, actually. I don’t own a computer.
Ghidora should have the image now though, so unless something else comes up that prevents him from doing so, it should be edited in relatively soon.
Hello. Has anybody a slender arm-design?
This is the MOC it’s supposed to go onto.
Is much skinnier now.
Anyone interested in a head design with Mixel eyes?
Well here you go
BTW, this was inspired by @Omega_Tahu’s design
The reason why there’s a 2x1 brick with a pin hole on top, is so the 2x1 bricks can be swapped so it’s compatible with the older kanohi masks (though the eyes will have to be taken off and placed back on)
Simple modification for masks like the 2008 hau
Go from a boring old transparent brainstalk to awesome Mixel eyes
Now you’re mocs can be cool like Voltak
Thank you. I’ll try in out.
Probably going to have to build one up so I can do a comparison.
Mixel Eye Master Race
