What’s the rest of the hand look like?
Something like this?
The one on the right is slightly modified to hold something more securely.
I don’t think it’s possible to build something much smaller - planning to use this design myself on a titan sized MOC.
that’s the thing i have no hand because those i’ve built were to big.
Ok, come to think of it there might be a smaller possibility…
I have no idea what that part I used to attach the thumb here actually is, though. But apparently it exists.
It exists in red on the praetorian guard. It also exists in gold and translucent clear.
Can someone help me build a long pole-weapon? I’m fresh out of ideas. It needs to be quite long.
did you try using lots of the technic sticks?
For everyone who has been asking me for this, especially @Toa_Vladin:
Here are all of the pieces you will need:
The limbs are the most straightforward part of the moc, so here they are. I would replace the metru blue feet with mata blue like the hands, but I don’t have enough pieces.
The torso:
Yes, that is a flipper.
I wasn’t very clear here, but the rubber band wraps around the stud pin and the neck.
Finally onto the head:
And now you are done!
Have a great day!
thanks
Thank you.
WOOHOO! Now I don’t have to try and reverse engineer her build anymore!
It’s not about getting it to the required length. I just want it to be a little more than two silver Gali hooks on each end of a long stick.
so uh, anyone has any design for high heels for a bonkle?
don’t ask any questions
put the circles into the sticks see if they make them look good
hmm, looks pretty good, I might try it
what’s the small piece holding the foot together?
How would you employ the turbines?
