On my CCBS version of Yahru, while I do like the look, I found something off with the knees. I could only get something like a 90 degree bend. What tips can you offer me to change the knees, or at least improve the range of motion?
With basic CCBS bones and shells, usually a 90 degree bend is the best you can hope for. If you wan to get more than that, I would recommend adding a third segment to the leg (a knee, basically) that would allow the thigh and lower leg to bend further.
[details=Here’s an example of this kind of knee.] [/details]
I would also suggest that it might be a good idea to change the shin armor, since the texture clashes with the smoothness of CCBS.
Perhaps instead of using the standard bones you could try using some l shape Technic beams with a leg design built off of that, it would allow you to add more detail and it would allow you to get the ninety degree bend if you play your cards right.
So if you look at the ccbs hand, it’s a pretty poor representation. It’s got a gigantic socket visible at the wrist and the thumb is positioned at an unnatural distance from where it should be. There’s also a significant gap in the center of the hand for some reason. And no finger articulation. Terrible, terrible part.
Now I’d like to introduce all of you boys and girls to these snazzy mitts. Same size as the ccbs fists, more anatomically accurate, and with more connection points. They aren’t half bad. TLG made them exclusively for two big figs, the Cave Troll and Goblin King in 2012. They are fully compatible with technic due to the axle hole at the wrist. That’s right. You heard me. In 2012 TLG had these hand molds at their disposal and chose not to reuse them.
Due to the limited production run, the hands only come in tan and sand blue and are only attainable by buying the respective bigfig on bricklink for ~$25-35 +S/H. To add a ccbs arm simply build the following:
@Omega_Tahu, Thanks for making that mixel eye/mask tutorial. I’ll be sure to use it! I just joined so I apologize if I’m late on replying. Thanks again!
