He tries something risky and attempts to partially transform so he could have use of his hands and still be able to fly.
He would find that of great difficulty, and probably great pain too.
He tries to fight through the pain and get to Drill Bit, even if he got hurt doing it.
He would eventually get him, only a few meters till the impact.
Tripredacus’ body slams to the ground with a big BOOM, which would likely distract even Gigatread from inside the tower.
@MaxinePrimal
She continued to viciously bite and pull at the armor, trying to get at the more sensitive and vulnerable parts.
All the while the claws on her hands and feet brutally ripping up his body.
OOC: Wait so is the body inside or outside? Because Gigatread is outside.
Forager cries out and hurries over to the window, sticking his head out to look at the scene below him.
“Guys!” he calls down to Transwarp and Drill Bit.
Ravenger yelled in pain.
Nitro shot his two arm cannons at him.
OOC: Outside.
They were too far down to hear him.
“Quick! To the elevator!” Beetle said as he ran outside the room.
Forager dashes after him.
OOC: Should I make a timeskip to the point in which they arrive to the base floor?
Razorclaw leaped off the Vehicon so both cannon shots would hit him instead of her. She jumped to the side of Nitro, and took a quick moment to look for Halfshell.
The body landed just next to Gigatread, causing him to jump back in surprise. He fell flat on his back, causing the tower and the ground around it to shake violently.
Scavenger, already down, would not be hit.
Halfshell, together with all of the other Seacons, Vehicons, with Scaleraker, Weirdwolf and Snapper, were fighting the Vehicon generals Swift and Tankor, together with other Vehicon drones.
Tripredacus seemed inert, not moving the slightest bit.
Moley warbles as it turns to have its blades face the inert Tripredacus.
OOC:
sure.
Slowly after Manta arrives to the (Supposedly) transformed Transwarp and Drill Bit. The first thing she did after she turned to her robot mode was to hug her brother tightly, kissing him on his cheeks, making him turn red.
“Oh… Hey uhm… Manta…”
“You would have sacrificed for us!”
“Yeah… Uhm… Sis… I can’t really breathe…”
Manta let Drill Bit go, as she looked around at Moley, Transwarp and Gigatread. Beetle, Forager and Slyther would have arrived just in time to witness the scene.
“After two months of running and running…” she said, raising the drive in the air. “We are finally escaping this hell!”
@MaxinePrimal @BlackBeltGamer98 @meepinater @Chromeharpoon
Gigatread stood up and cautiously approached the predacon gestalt. He nudged the body with his foot.
Razorclaw considered ditching the group then and there, saving herself. They seemed to be handling the situation just fine on their own anyway.
Then again, a general’s command chip would look perfect on her chain. She already weakened one of them. This was an opportunity she’d rather not waste.
Quickly she pulled out her rifle and loaded it with a stun cartridge. A bolt which has a much higher chance of hitting it’s target, while doing much less damage than a regular bullet. Instead, it would immobilize the target for an extended period of time.
She fired three at Nitro, hoping that at least one of them would hit.
The body quickly disassembled from the impact in three sections, tho those sections do not revert back to their robot modes.
OOC: Tho I don’t want you to kill any of the generals… At least not yet…
While Razorclaw was contemplating on what to do, Nitro shot two laserbolts himself at her.
OOC: Okay but this is Scavenger we’re talking about. The others would probably be better off without him.
She dodged the shots easily and continued to try to immobilize Nitro.
OOC: Other than Swift, Inferno and Blastcharge, at least one of these generals will show up in the sequel. I just haven’t figured which one yet
He turns into his jet mode and tooks off, which would probably make Razorclaw loose her balance, before suddenly reverting to robot mode and attempting an elbow drop.
OOC: Taking a little bit of Prof’s trend over here.
Forager doesn’t celebrate yet. He had to be sure Tripredacus was dead.
@MaxinePrimal " 'Ey, big guy!" he shouts to Gigatread. " 'S he dead?"
She fell on her back. Looking up at Nitro, she had just enough time to roll over and avoid the hit.
“I believe so.”
He replied.
As she would fall back she could feel the heavy steps of a tank drone shaking the ground as he approached her.
