And I will welcome it, don’t want to end up dealing with another Sun again.
@Runa
Oh yeah, if you want one just ask! Certain you could think up aomething interesting for one of them.
Also, anyone notice the little references I threw in with 'em.
@Runa
I couldn’t take one on. I have enough trouble with all my…everything.
Ey, awesome! He’s all yours!
Quick thing I forget if I mentioned. All the cults main basis’s are around the prepartion to combat Sun/any similar entities should they appear, but their teachings are not limited to only the removal of those kinds of evil.
While the scenario must be quite serious to prompt their interference, if it does reach such a level they will lend a hand in fighting whatever ‘evils’ have currently appeared. (Such as with the Skull spiders/remnant skull villains. While the cults did work to help eradicate them they still would’ve kept their efforts as hidden as possible.)
Ok so basics for Kipir, his cult is called the Cult of The Tide Dancers, but this can be changed if you’d prefer another/can think up a better.
They’re mainly water-based, location-wise. It ranges from a mixture of underwater tunnels/buildings, and a medium-sized or so island in the middle of said watersource (be this lake, ocean, or otherwise is up to you along with the region location).
A number of the tunnels lead to the embankment around their cults location, and end in very well hidden entrances to allow the cultitsts to leave to collect supplies, or return home if they are not permanent residents of the base.
Kipir keeps them hidden by using hisfog ability to create a large dome/cylinder of sorts around the island, and uses his liquid-form to forcibly ‘guide’ approaching boats out of the islands way once they enter the fogbank.
The area they’re located would be semi-well known for its mysterious fog, and the odd turnaround any sailors/boat-users find themselves experiencing within it.
You can add more to these as you wish.
His cult is mainly composed of Ga, and Le-Okotan, but there is a small number of Ko, and a very small mixture of the few adventurous Po, and Onu that know of it.
They are trained in water based combat, and minor-stealth. Both under, surface, and boat. They accomplish this through a mixture of swimming/movement based training, and tech (respirators/limited breathing aparatus, turbines, etc).
They are trained in the usage of spears, tridents, weighted nets, and a form of martial arts/restraint based combat training.
All the cults teach this form of restraint based combat, but each has their own unique ‘flare’ with it (user dependent), and is generally used only in dealing with infiltrators.
Any chance I could join?
If so, could somebody give a rundown of what’s happening?
I would normally say yes, and still will say yes. My only concern is that we’re getting close to the end, as the RP ends in 21 days. There is talk of a spiritual successor of this RP that will continue the story, however it will not be by the same GM, @Runa, some of the players of this RP are saying that they will GM that RP.
The whole rundown really depends on how much of the story you are looking for, but I’ll give you the current situation that we are in. The enemy Skyll is attacking the city and trying to take it over, she leads the army of Skull Spiders. The main cast is trying to take her down, though it might not happen and eventually we are going to face makuta’s baddies.
Go ahead.
I might not…I
I had another idea for an rp g so I’m gonna see if that kicks off.
@Runa
any chance there’s gonna be another one after this?
Edited For Double Post - BioKnight
Gender: Male
Element: Water
Powers/Equipment: Mask of fog, a mask that allows its user to cover a large area in a deep fog. Kipir is also the mask itself, so detaching the mask would render Kipir’s current body ‘dead’ until the two are reunited.
Kipir also possesses the ability, like his siblings, to ‘use’ the bodies of other individuals as his own when his mask is worn by them. Very few have the mental capacity strong enough to avoid complete control over everything but their mind, those few often being either very old or very mentally skilled.
Appearance: Kipir has two forms he uses. One is his original body, a metallic emulation of the average water Okotan, powered through water. The second is quite literally just his element itself. While it is unknown to the others how he accomplished this, Kipir can somehow form a semi-physical body out of pure water. While it suffers a few restrictions, such as being unable to leave its connected water source, and still requiring his mask be worn, it gives him an immense advantage over others, quite easily making it impossible to harm him in anyway besides hitting his mask. Doing so temporarily disperses his original body.
Bio/Personality: Kipir was forged for the sole purpose of dispelling any and all evil in as secretive a manner as possible. Kipir is the calmest of his siblings. Quiet, meditative, studious, and honestly a touch disturbing at times with intensity of his focus. He also has a generally pessimistic outlook of life and among his siblings has a reputation of being impossible to argue against.
If there is, someone else is GMing it. We’re currently working that out.
I am seeing a promising trend of Living Kanohi characters and I’m curious to see how they’ll turn out.
You should post it here next time @Antroz2007
There will be a next time?
I mean next time you sign up for an RP, you should post in the signup topic
So I need to sign up in that topic OK
I believe you forgot his equipment. Try writing the signup again here and I’ll look it over, assuming you still want to join.
