Way back in 2003 or 04, you gave us a list of Rahkshi armor colors (http://www.bzpower.com/ref.php?ID=1567). Granted, this was a very long time ago, so if you’re unable to answer the question, that’s understandable but, some of these colors seem a little uncertain as to which respective LEGO color they’re intended to be; particularly Purple, Light Purple, Magenta, Aquamarine and Gold (since we’ve had several shades of gold)
Do you know what respective Lego colors these would be?
I would suggest:
Purple - Dark Purple (common in modern sets) (official name ‘168 Medium Lilac’)
Light Purple - Purple (seen in Tohunga Onepu) (‘104 Bright Violet’)
Magenta - Magenta (‘124 Bright Reddish Violet’)
Aquamarine - Teal as seen in Tohunga Kongu (‘107 Bright Bluish Green’)
For reference, Ryan Howerter’s list of LEGO colors: http://ryanhowerter.net/colors.html
According to Bricklink, there was a colour called “Light Purple” that was inctroduced in 2003. However, from what I can tell, the only sets that actually used it in 2003 were Clikits sets, and the only “Light Purple” parts were some paper cutouts (which aren’t usually exact matches with plastic bricks of the same colour):
I think the only other colour that was used at that time which could reasonably be considered “Light Purple” is Sand Purple.
True, but the original list only said that Heat Vision is “Yellow”, which definitely existed at the time. This seems to be proof that the Rahkshi colours can have some variation in exact hue, though too much variability could lead to confusion between two Rahkshi (most notably, Disintegration and Molecular Disruption are Blue and Light Blue, respectively).
Also, I have a bit of an addition to the original question: When a Rahkshi is described as “Gray”, does that refer to Light Gray or Dark Gray? Typically, I don’t think such minor variation would matter, but I think it does in this case because the difference between Light Gray and Dark Gray is the difference between a Rahkshi of Limited Invulnerability being completely monotone or having two shades of gray.
BL “Light Purple” (198 Bright Reddish Lilac) would probably get confusing, as it’s sort of inbetween of Onepu Purple and Magenta, pretty close to both, and intended as a replacement for Onepu Purple. In retrospect, I’d probably have said Sand Purple (136 Sand Violet).
Light turquoise aka Medium bluish green (116) would work too, I agree. The Medium green (29) seems a little too green for the job.
I still think dark turquoise aka Bright bluish green (107) still seems off for any color called aquamarine. And parts availabaility shouldn’t really be a factor since none of the specialized parts were produced in any of these colors.
One would need to make the parts anew, no matter which color is chosen.
I’d lean towards 107 because it was used in BIONICLE, but that aside… I wouldn’t really count Dove Blue’s use in 2003, because that was in Clikits. Clikits used a lot of other colors otherwise considered to be introduced for 2004.
Of course, by 2003, all of these colors existed internally, since that’s when 2004 sets were developed. They’re included in this list given to Peeron back in 2003: Color List (Interestingly, the Clikits transparents 227-236 are not, and neither is 182 Tr. Bright Orange.)
That said, if we are including 04 colors (given Heat Vision), then the unused 211 Turquoise is probably what’s closest to Aquamarine. Some samples from its use in Modulex:
