Many, many years ago, SG-1 first entered the Stargate. SInce then, many events have occurred and the Stargate had to be buried and, presumably, destroyed in order to save Earth. The air force base built around it was razed to make place for newer facilities, and now, on top of the site, is a brand spanking new Army Base.
However, strange things have been happening. Strange creatures and beings have been reported to be wandering the halls of Andromeda Army Base. Staff is becoming uneasy, and the General is worried.
You and a team of other like-minded soldiers will explore the base, searching for the cause of these strange occurrences. Little do you know, the General has bit off more than he can chew.
Character Sheet:
Name:
Gender: (Male or Female)
Weapons/equipment:
Appearance:
Rank:
Bio:
Some rules for the characters: Use modern American weapons and ranks. No ranks higher than Sergeant Major of the Army. For now, only one character per person. Once we get in depth, I will allow access of more species and characters, as well as weapons and equipment. When you make a change to your character, edit the sheet accordingly and let me know in a separate reply.
Playing Rules: No auto-hitting or one-shotting. No characters with loads of weapons, or OP characters. If you have a question, ask the GM.
Worlds:
Planet IX-12284 (Verdanta):
A lush, green planet with high humidity. It is much like earth, although the local plant life seems… sentient. Reports say that the insects are larger than usual, although the exact parameters were not specified. Information recovered from old SG-1 database
Planet IX-34885 (Grits):
Much of the planet is a large, desert. Many oases scatter the land, and the north and south poles are densely populated cities in a well watered environment. The inhabitants are unknown, as the planet was only recently discovered and documented by drones.
Planet IX-56833 (Unknown):
Nothing is known about this planet. All information was destroyed after SG-1’s decommission.
Known Aliens:
Ghast: A transparent grey humanoid, with wisps of smoke coming off of their body. They are neutral, but can become hostile. They can take over a person’s body for a short time.
Tortle: Humanoid turtles, with green and brown colors and a shell. They are slow, but have extremely long lifetimes and are very wise and friendly.
Jaffa: Genetically engineered and modified Humans, who often hold a Goa’uld in their bodies
Goa’uld: Parasitical sentient beings who live in the abdomens of compatible hosts. They often have a violent, cruel and superior nature.
