Sinker was sent back a few inches, Line kicked Galvatron in the leg.
He takes the hit and grabs Lineās arm. Swinging him around and smashing him into Sinker.
Sinker was sent back a few inches, while Hook stabbed his, well, Hook through Galvatronās hand.
With a clench of his fist and a twist of the wrist, the hook snaps. He then turns around an punches Hook with the damaged had.
He ducked and kicked him in the side.
He dodges and uses Hookās own momentum to push him onto the ground. Holding him down with his foot, he shoots at Sinker.
It bounced off sinker, while Line stabbed Galvatronās Arm Cannon.
He pulls his arm in and pries the sword out of Lineās hand. He then grabs his bad arm at the elbow, rips it off, and throws it as Sinker. Then he makes sure to stomp hard on Hook.
Hook tried to roll out of the way, but his arm was crushed, Sinker smashed into Galvatron yet again, while Line stabbed him with his sword.
He dashed to the side, and let Sinker crash into Line.
Line was whacked into the wall, but Sinker turned and smashed his fist into Galvatronās face.
He ducked and used the jagged piece of hook sticking out of his hand to stab Sinker.
He brought down his fist as slammed into Galvatronās head.
Galvatron took the blow. He backed up and pulled the sword out of his cannon.
OOC: Since when did he have a cannon sword?
IC: Hook tripped him, while Line kicked him in the back.
OOC: Line put the sword in the gun. Galvatron pulled the sword away from Line. Then he takes the sword out of the gun.
IC: He jumped when Hook tried to trip him, and landed so that Hook and Line where to his sides, and Sinker was in front of him. He fired the cannon, and due to the hole in the sides, the beam split. Two smaller blasts hit Hook and Line, and the main one hit Sinker. All of them where weaker than the normal blast.
The cannon exploded from the damage, taking Galvatronās Arm with it. Sinker pounder Galvatron into the ground with his fists.
As close as they where, Hook and Line where both incapacitated by the blast. When the dust cleared, Galvatronās face only displayed seething rage. He dodged Sinkerās charge.
Sinker smacked Galvatron with his fist.
He took the hit, and did the same to Sinker. He punched much stronger than before.
