“However, dragon. If you are willing, I shall lsiten.”
OOC: Listen.
“For I could use a herald like you. Your brute strength, and your blind ferocity. I could use a savage like you.”
“Well you have no other choice!”
Chains manifested from the shadows and wrapped themselves around Gronius’s limbs and neck.
“Beast you are and beast you shall stay.”
“Fool! You are in no place to bargain. I do not need your compliance. I only needed your physical form, to use as my puppet.”
“You have no say in the matter.”
The chains let out a painful shock.
“You are to be my mindless slave, and nothing more.”
Gronius was forced to transform against his will. The chains still holding his dragon form.
OOC: You won’t control him. Plus, I was going somewhere with that!
Gronius yelled scared.
OOC: I wasn’t planning to. You still control him, just as a savage beast.
IC: “Your body is mine to control. Now, you belong to me.”
OOC: No! I am not OK with this!
Gronius transformed back to robot form.
“Maybe you can’t control me because I am not from this world, remember.”
OOC: I don’t want to have Gronius like this.
“Listen here. I will be your herald. But one: I am in robot form and with free will. Two: you save Song.”
OOC: And also, bye!
OOC: I have a plan. He’s not going to stay like this. Trust me.
IC:
“Beast You are and beast you shall stay.”
He transformed again.
“You have to power to bargain. You are my slave, and that is final. You may have your will, but you shall do exactly as I command. Disobey me, and you shall suffr. But do not worry about your sister. I can assure you, she will not be harmed.”
OOC:
IC: Gronius just listened, knowing that if he roar Song may get hurt.
OOC: If I don’t have Gronius back in at most 100 replies I take him myself.
@MaxinePrimal
OOC: 1. I never intended to control him. 2. Did you not ewad the last post? Unicron said he could have his will.
OOC: No. You said that you have a plan. I expect it to end in 100 replies.
Gronius was waiting for the first order.
@MaxinePrimal
OOC: Well I thought a bout things a little bit and a I changed the plan. Gronius won’t be Unicron’s slave for the rest. I promise that this isn’t permanent. But I can’t promise that it’ll be fixed within 100 posts.
IC: He then spoke to Wildsong.
“Now you. The four arm. The freak.”
The Axis clones began to fight Direwolf.
@Traykar
Direwolf slashed at them with his sword.
The blades went clean through them, severing them in half. Each clone dissipating into shadow with only a single hit. Though they where great in number, and managed to get a few hits off on his back.
