So here is the new version of my celf-MOC (already got a cringe from ya) woth a little twist…
SYSTEM.
Probably not as good as the last one but personally I like this version a lot more. Only thing I couldn’t integrate was the rifle of cringe but that’s fine, I like the pun-pistols.
is it the same size as normal okotans? I think it looks much better than the original aesthetically, but it looks somewhat unstable. the shoulders are built weird, and have unnecessary joints imo.it should also have bigger hands and slightly beefed up lower arms at least. the ankle joints are placed strangely imo since there are off centered. the lack of hip joint is acceptable, as it would mess with the skirt. it looks very smooth in most places and the shaping of the hips up is excellent. it reminds me of a samurai, with the swords and armor skirt. it’s a good system moc, but not exceptional. I find it a lot easier to criticize system since I build in it a lot so I may have been over critical, but I hope I didn’t come off as mean. do you build in system often, and are you planning to make multiple versions of this?
I kinda wanted to redoo the skirt from the sides cause @Plural is right, the studs look horrible. At the moment I don’t have other wing pieces I could use to makie it smoother so yeah I will probably redoo the side. As for the arms I could beef them up later, the hands might be tricky but I will probably beef them up too.
As for hight it is the same as Kivoda.
I really like this, although I kinda miss the rifle of cringe. but still, it’s a good system moc, although the arms look a little stubby, but that’s just a nitpick. Other than that, it’s pretty solid.
