Hello, as you may know a con listed with the 2016 bionicle winter sets is that the eyes lack proper light piping, making the figures seem dark and soulless, I have observed that the con is mainly blamed on the new, shortened eyestalk, after listening to the TTV podcast episode 180, where this issue is discussed, I decided to do a bit of research with the Bionicle sets I have in my possession. I have found that the problem is not with the eyestalk, but with the new masks introduced in the winter wave.
Now let me explain.
As many have noticed, the set Umarak the hunter has fine light-piping, it has been said that it is due to the trans reddish orange eyestalk catching the light better than the trans bright blue seen in the Uniter sets. But the color of the eyestalk has little to do with this, while it is a brighter color that catches the light better, the main reason is Umarak’s mask, it covers the face, and only slightly covers the top of the head, as to allow his antlers to mount on his head. The mask is also melded with trans bright green on the top, allowing light in even better, and when used on a head with a bright trans blue eyestalk, it can even make a gorgeous bluish green color. Now when Umarak is wearing the mask of control, his eyes can seem a bit darker harder to see, seeing as the mask of control’s design curves and covers the top a bit better than Umarak’s mask. also seeing as this mask is not melded with any transparent plastic, also contributing to this factor.
now what about the Uniters?
Notice something about the Toa’s masks. the Toa’s masks cover almost everything but the back of the eyestalk, murdering most useful light piping. I have noticed that unless your light source is directly behind the figures, the eyes are dark. now for people that use a display area with only an overhead light, you are doomed to have dark eyes on most of your sets.
How do you fix that?
Many have suggested swapping the eyestalk to the older version from 2015, cause that must work, right?
Wrong.
Swapping the eyestalk to the older version does nothing but hinder the unity function and cause the mask to fly off.
But what about those “worthless” melded masks that came with the uniters? As not many of you have noticed, the eyes light up great with those masks on, because even though the top of the head is covered, the light can shine in and make a wonderful glow. all thanks to the transparent plastic, even in unity mode these masks work decently to provide better light piping.
TL;DR
The uniters eyes do not lack light piping because of the eyestalk, but because of the masks.
