it has two tails, the mata hands look strange for feet, the hands are pretty bad and the Rhakshi head doesn’t really fit with the build. I really don’t mean to sound super negative, but this guy(gal) could use a bit of work
The mata hands will probably be switched out for Ben 10 feet, the hands will be changed but I don’t know what to, the two tails will probably stay but will be swapped for different parts, and the rahkshi head if the only one I have that looks remotely feminine, so that’s staying. @JMP The colors will be changed later. @Rockho But horses have hooves…
The incoherent color scheme is probably its biggest issue, as it creates a model that’s somewhat hard to see.
I think the build itself is pretty meh, with an abundance of open pins, axles, and gaps littered throughout the MOC. I’m also not a fan of the overall appearance of the Centaur. It just looks extremely awkward. As stated by @Rockho, the legs just aren’t horse-like. The “hooves” get the overall idea across, but they’re kinda odd-looking. The Throwbot arms, although unique, doesn’t really look like the tail from the actual creature. The arms are custom, which is an aspect of the MOC that some might compliment, but I think they’re a bit too thin. I’m also not the biggest fan of some of the unnecessary greebles, like the Dragon Bolt lighting pieces and the Trans. Neon Green Technic pieces.
I have never read a sentence more true in my life. I mean look at the color scheme it’s dread for. Also work on the legs they look a little off.
I think with “a lot of work” this could be a real groovy MOC.
