Is it possible to, for example make a custom mask in studio to have a secondary colour of metal blue, or dark purple?
Thank you! I’ll check it out.
Yeah Like Atobe said, Swamp Kryakwa’s pack has some very nice fusion colours. I’m using them to make some Inika/Mahri revamps right now.
For example.
The issue comes in if you want to make your own. It uses a coding language to create the blend, possible CSS if I remember.
As you and Atobe have said, the easiest way is through colours, while it’s not perfect every time, you can modify the colours a bit if you need to, don’t bother making custom parts just for the purpose of them being dual-molded.
Where can I find the template values of Dark Purple and Metal Blue colours spesifically? Since I need the shades to match the default studio colours.
I looked in the /Studio/CustomColor there are only luminous and translusent colors listed as templates.
The actual color file is located somewhere else. Are you trying to do a half/half blend of dark purple and metal blue? I can make that for you.
I was thinking somewhere between 30-40% blend, with Dark-Purple as a bottom colour and Metallic-Blue as an upper one, I hope that would look good enough. Do you have the template and right values?
Template for a blended color? I can send you something on Discord.
I’d really appreciate it. I’m on the Bio 3d modeling server right now, template with right color shade values and fusion configuration would be enough.
I don’t go on that server anymore (and honestly I think people should stop linking it. they’re nothing but trouble there). DM me KDNX#7760
