Glatorian and agori are two different species. at birth a glatorian is completely biological. they can receive mechanical implants though.
Engineers?
Engineers?
Never mindā¦ Iāll stick to what I have. Shamans are Canon to me, even if a story full of warriors proves not.
Are you insinuating something about the Tukar?
Yeah. again, your moc your story.
@Hutere_the_Toa_of_Air
Youāve trashed canon so much I donāt even try with you anymore
Cāmon.
Because Artahka.
Anyway, thank you again for the feedback. Once I have the legs figured out Iāll move on to the cloak and then painting where it needs to be.
Play nice you two.
Itās an inside joke.
Oh
Thatās what they were
ā¦well they still look like exposed pins to me, pretty sure you could achieve the effect with something that looks less unfinished.
So thatās meant to be the upper limit of her torso? Implying the rest of the upper torso should flow with it?
Not sure what piece to add with the same look Iām going for.
Not completely sure what you mean? Upper limit?
As in, if the silver piece is a ācollarā, then all the rest of the pieces immediately below it should be arranged in the same circumference so that the ācollarā flows smoothly into the shaping of the torso.
Not sure if you can envision that or not.
Ah. I see what you mean. Thereās a chance I might end up removing the tubing. Thatās still up for debate. The moc looks good with and without it.
That is definitely staying. Iād paint it if I could. Iām not removing it. Thank you anyway.
Velikaās inclusion in these pictures cannot be a good thing.
Velika is my next planned model. Once I get enough black pieces and a black Rau.
Velika was rebuilt as a matoran. That means even the mask was changed.
Makes you wonder where his original mask wentā¦
not exactly.
think of toy engineers.
anyways, any progress ad of late?
