Hi everyone. Here is my ‘Kopaka Master Uniter’. Basicly Kopaka 2016 with the gear function of Kopaka 2015. But also works in Unity Mode. http://i.imgur.com/kJ9QhwU.jpg
I wanted to do this since they were officially available (in US), but I had to wait (because I’m from Europe).
It is made of Kopaka 2016 and Kopaka 2015, a friction adding gear+pin (which I took from Gali 2015), 6 long axle and 1 “spare piece”-piece.
Took me one night to build him.
http://i.imgur.com/Nmpoy7A.jpg
Even in Unity mode you can turn the piece on the back to move the (left) arm up and down.
http://i.imgur.com/v4u3cOd.jpg
Wanted to make them (also Melum) look, just as the original sets, but with the arm function.
Impressive, seems strange that no one ever made this before… Well, I guess those great mocists out there are unable to work wit gear functions. /s?
If you want to improve the look of this you should rework Kopaka’s upper arms and the way the axle hides in Melum, other than that it’s good.
Again, really ingenious. My compliments.
If I could I would try it with the other sets, but I restricted myself to only buy Kopaka and Umarak.
So go ahead and try it yourself I guess, be sure to link/mention me then so I can see it :
Yeah, the shoulders and Melum’s axle were my main obstacles. I restricted myself to only use parts from the two sets (which I already failed in with a axle).
In an earlier version Kopaka had a long function axle, which went through Melum’s body, but changed it soon after to what you see now (too bad I didn’t made poctures of it).
If you want more pictures of the build you can ask.
http://i.imgur.com/Ckfqy3m.jpg
The unity piece is besides the one-half pin not really connected to the torso, but with an 3-long axle to the grey piece.
Don’t know how to explain the instructions better…
I reworked it and tried to make the axle in Melum less obvious. Which did work, but as some other flaws. Also I don’t need the extra 6-long axle anymore. Have a look: http://i.imgur.com/XqPi2u3.jpg
No obvious changes
http://i.imgur.com/ZoBsXVU.jpg
(Had to lift the piece up on Melum… >,<) On Kopaka there is a 4-long axle on the left side of his body, later used for unity mode.
Preparing for Unity Mode http://i.imgur.com/eQItKKi.jpg
Storage of the yellow is now more hidden and nicer in my opinion. Also adding now the 4-long axle.
http://i.imgur.com/jaaJM1W.jpg
Better look at Melum’s back. Just as earlier version, take the action pieces to the lower axle.
The flaws: http://i.imgur.com/vrigh7z.jpg
In some cases both the black connector piece and axle can stuck to Melum while disconnecting them from Unity Mode.
