Matatu Kanohi 3D Model Blender
I modeled Nuju’s noble Matatu in Blender. It would be a lot easier if I actually had the mask, but I didn’t, so I searched references online.
Kopaka model from Maphrox BNG asset.
I modeled Kopaka’s shield since the BNG Asset didn’t have Kopaka’s shield.
(Currently working on Kanohi Power animation tests.)
A bit… melty, but otherwise pretty accurate.
It doesn’t look exactly like the mask, bit it’s pretty close
Not the most accurate, but I guess it works pretty well with the Kopaka model you have there.
Thank you. Maybe I should’ve applied a subdivision surface to the mask.
Thank you. I didn’t have the mask, so I used references on google.
Thank you. Hopefully my modeling will improve next time. Masks are very challenging to model for me.
Thank you. And yes I modeled it since the BNG asset didn’t have Kopaka’s shield, so I searched for a reference image online to model in blender. All I really did was start with a circle and then extruded more vertices from the circle to form the shield.
The mask is good enough IMO, but for some reason I’m really loving that Kopaka Shield. Did you also design it?
