Protip: Learn to recognize jokes such as this and the like as just that: jokes.
That is to say, don’t do the dumb thing and respond with some sort of threat or what you may perceive as a witty comeback. It likely won’t work.
Note: unless of course you mark your counter with lots of 1337 sp34k or udder soch por gramr. Then no one will think you’retaking it seriously, and it’ll be fine.
Legitimately good advice for when you’re sick. I’ve just had the flu for like three days and couldn’t eat anything, either because my digestive system would reject it or because it tasted horrible, but I found today that potatoes are seemingly the perfect solution.
Well, they are packed with Vitamin A and B, not to meantion a little bit of C. And the cholesterol and carbohydrates also would help you in your body. Potatoes are basically a super-food!
Pro Tip: Avoid taking on big community-based projects if don’t have the drive to finish them in a reasonable amount of time. Even if you enjoy it at the beginning, you’ll soon regret it because you constantly feel pressured to finish it.
pro tip: if you’re not sure what to say, simply say “So it has come to this…” It adds dramatic tension and is a valid observation in literally any situation.
Pro tip: If you want to respond to someone with a quote from another topic, select reply to that person and without closing your reply, go to the topic where said quote is. Now highlight the quote and select “reply quote” as you normally would.
