On the instructions, whenever I try to put on the mask, the skull grinder’s horns get in the way and I can’t put on the mask correctly. I even tried putting on the mask before the horns but the mask would pop off whenever I placed the horns on. I can’t even place the horns on correctly and the horns will be half-off cross axle connected to the face.
Anyone know how to fix the problem?
Could you take any pictures? I didn’t have any issues with my Skull Grinder, so you might just be putting the pieces on wrong.
Yep that’s what I assumed. You need to turn those technic connector pieces so the long part is attached to the axle.
yeah, so the Turaga hand pieces are supposed to go the other wa, with the long end coming from the head.
I did what you said and it worked. thanks!
Well if your question is answered…
This topic is now closed. New replies are no longer allowed.
twas fun helping you
also thanks cal
