Voruah, Toa of Lightning
This reserved Toa hailing from the Southern Continent is mainly occupied with protecting the Matoran population from particularly vicious Rahi.
His Kanohi Faxon allows him to turn the beasts’ strengh against them, and his two-pronged protosteel pike doubles as a cattle prod.
(Taking pics on a white background was a mistake)
This is really phenomenal! There’s a lot of great detailing without being too busy. I like how you attached the friction pistons, too. The white background is actually not really bad; it makes it look very clean.
Interesting use of the Pistons. Does it give the moc the flexibility for a high kick pose?
I had to use them there because of the way I built his lower torso. Since I used an inverted nuva chest I had to give him a 7 wide hip joint and the pistons make it more stable. Also no, he can’t kick unfortunately, the furthest the leg will go is about 45 degrees forward and back. Works fine for me tho
That’s a neat torso design! I don’t often see the Nuva armor used like that.
I really like this MOC. The proportions are unique and well-defined without being so different as to look goofy. The clear, monochrome colour blocks are also done really well.
Took me long enough to take pics of him on a non-white background to make his limbs stand out.
Unless there was sizable changes to the original moc (which it doesn’t look like there was), please keep all the images for the moc in the same topic
