I want to paint a 3d printed part, Does anyone know What the best kind of spray paint to use is?
I think pretty much any brand that’s plastic-friendly will work. You can probably find a good brand at your local hardware store. I’d advise going against anything that’s glossy, unless you want that look.
If you want to do a bit more detailed color scheme, with less hassle, however, I’d use acrylic paints. They’re brush on, and can be diluted with water so that they spread a bit more easily. I’d personally recommend acrylics over spray painting, but the choice is ultimately up to you.
Acrylics are also easier to clean up if you make a mistake.
Thanks!
