Personality: Quirky and Adamant
Abilities: Perfect Auditory Retention, Rhotuka Power of Sleep
Weapons: Duel shoulder blades, transformable into a Rhotuka Shield.
Mask: Calix, or Hau
(I don’t have a Calix, and I don’t think it could connect with the head connection. I also think it may be over-sized.)
Though mainly composed of CCBS, I thought the small and simplistic build made her look petite and feminine, and all the colors work really well and look beautiful together. I hope this is a good entrant to this great community project. Thanks for reading!
Thanks for letting me know. I wish you would have given me some thoughts on the MOC though.
@Square Thanks for your thoughts. The only somewhat exposed area is the bottom ball joint, but I wouldn’t consider it exposed, considering it’s there on a handful of official CCBS sets. I did try your idea when building the MOC, but I thought it looked better without a skirt.
The arms could use lots of work, for example the arms are completely trans blue but the legs are black, so you should name say the lower arms black, and I get the idea for wrist blades but I think it still looks bad, the shoulder connections seem a bit high for me.
I think you should go for a full custom torso so you can use a normal metru head and get rid of that crotch gap.
