Thank you @darkbrick999 for the name
just a thing I did. What do you think
obligatory Nyran shot
Not a fan of the mask, but other then that I find this MOC groovy.
How did you connect that armor piece o the lower leg?
Honestly, I don’t like the mask a whole lot either. Unfortunately there’s no lime-green masks, so I used the only “neutral” colored mask from this wave
one “flick-fire missile” piece, two really short cylinder shaped pins and an Exo-force robot hand
I highly approve of the torso build. And everything but the mask.
In all, really nice!
Not sure about the mask of control, but I like it.
Also is it a boy or a girl? Not that it matters, I’m just asking.
@PakariNation99 @Yveran
well, looks like I gotta find a new mask XD
I didn’t really build it with a specific gender in mind, but if I had to say, it would probably be male (the right hand being tipped up in the last picture was unintentional btw)
Looks pretty nice! I like the colors a lot.
Thanks man
simple, but nice. He needs a creature. And name him Tupuhi, Maori for “gust”.
It’s too bad the mask doesn’t come in a line green. I ran into a similar problem when building my self-MoC.
Currently I have only the fire creature’s head, gonna have to pick up another one later.
thanks for the name
Your welcome. Oh, the wonders of Google translate.
I suggest trying to use a trans green mask from g1, I’m pretty sure 9 times out of 10 they’re compatible with creature heads.
Pretty sweet! I have only two small nitpicks:
Other than that, I do really like the combination of lime and yellow, and I definiteley dig the HF armor on the Uniter bod!
Good job!
Most of the G1 heads are too big, I probably would have used a Mata type head, but I don’t have any in lime. The best fitting lime head was from Breeze 1.0 and it looked kinda odd. Using the Mask of Control was pretty much my last good choice.
@FatCat23476 I’m pretty sure it’s too big. I’ll post a picture of it in the comments in a moment.
wasn’t even aware this was still a meme.
As for the MOC itself
I think the upper arms should be swapped for other things, as there’s no trans neon green anywhere else
and the Mask of Control may not be the best fit either.
@TheRed1s
Also, small question, is the “brain-stalk” the longer 2015 one or the short 2016 one?
I’m using the one from this year
In other news, here’s Tupuhi wearing every reasonable mask I own
@GIF.Man.Ben @PakariNation99 @Yveran @SwagMeister @FatCat23476 @Nyran
I think I like the Breez helmet, as the “eyebrow” lines match up well to the lines of the shoulder spikes
