I’m back with something slightly different. This is Kahro, a Dark Hunter who goes by the codename Red Blade. A Dark Hunters who specialises in hunting Toa for the right price.
Kahro was once an Order of Mata Nui member before leaving the group when it got disbanded. Kahro is very old bu is considered to be one of the greatest swordsmen on Spherus Magna. He wields a large red rapier made from a large Nui Stone. The blade is capable of draining Toa Power when activated. When this happens the blade begins to glow dark red. The blade can then cut throgh things easier but becoms harder to wield and more fragile when activated for longer periods of time. Kahro replaced his normal right arm in order to use the weapon more effectively. The sword is incapable of making Kahro stronger because he is not a Toa but he can use the stored Toa power in order to fire of powerful red blasts of energy from the blade. This action reduces the drawback of the weapon by discarding the stored energy inside the weapon, making it easier to wield and less fragile.
His glider goes by the name of Midnight Sky. It’s a specially designed glider with a focus on durability, speed and firepower. It is also impossible to detect the vehicle with radar due to it’s design and can travel silently at lower speeds. The glider is equiped with two large cannons, a smaller turret, tracking devices, sharp blades and a towline that can be detached. It can be be controlled remotly thanks to Kahro’s right arm and go to autopilot on command.
His kanohi mask is a Jutlin, capable of making a target rust.
The real life inspiration for this vehicle is a Northrop Grumman B-2 Spirit.
