This looks really good! I really like the colors. Also, I really like that hair. (I hope you don’t mind if I use a similar concept in a future build) I feel like the neck should be slightly linger, since it looks like she cannot look down. The waist also looks like it could use a little more bulk, but besides that, this looks great!
Oh look, people aren’t dismissing it because it uses Nuvaboobs.
Although personally I don’t think they fit the very Technic-y/mechanical look of the rest of the MOC. That’s a styling I don’t see a lot of, and it sets her apart from most other MOCs, to say the least.
Lowering the bust (not the shoulders) by about half a stud or so (if you can) would make her look a little more human and maybe improve her head articulation. Apart from that, I really like this MOC. The build style is very technic-y and not something I’d do, but I really like it. The fact her legs can join together to form the tail (?) is awesome too.
Would recommend putting some trans-dark-blue on her as well. It’s present through her mask and hair, but a couple of other spots/highlights would help out in key places. Maybe in those empty pinholes on her shoulder panels, or a heartlight, for example?
You know that dose sound like a good idea, to add more trans blue part, the reason why I didn’t do that is because I don’t have that much of trans blue, but I’ll give it a go. As for the tail I did try to made it look like the legs come together, but sadly fail, so instead I just made a separate part. Thanks for the advise.
Very nice! I like the color-scheme, as it implies both tangible states of water. I forget, does Aquarius control Ice, or is that a separate Guardian? Anyway, the tubing gives the effect of watery braids, which is intriguing, although they are rather stiff, as is their nature. I like how the horn pieces that form the tail can attach to the back. The trident also looks cool, and I like how the blades point towards each other.
I agree that more trans-blue would be nice, particularly due to the mask you chose. Of course, you could just as easily change to a solid blue mask, but that might make the MOC too different.
