Just finished my Muaka and Kane-Ra builds. The first two are based on the official set, and the third is the Kane-Ra is based on how it appears in the Mask of Light game for the Gamecube.
I’d love to see a render of the model with the mouth open, if it can open, since right now it seems a little toothless on the top jaw.
one open-mouth render, as you requested. as for upper mouth teeth, i chose to go with what the original set had, the Muaka has only two teeth on the upper mouth, and the Kane-Ra has none. also, i forgot to mention that i will also be designing a Muaka cub and a Kane-Ra calf at some point.
Cute! They certainly seem pretty accurate to the originals; the heart-piece as ears on the Kane-Ra are particularly clever, and the tubes are a nice touch.
Thanks! I was so happy and surprised when the muaka’s teeth fit together properly without causing issues. In my opinion, my biggest brain moment in the whole build was using the lipstick pieces for the eyes. I had been lamenting from the very beginning how I was going to get the heads to look right, and for things to just flow so naturally once I got to it, was frankly a stroke of luck.
Wow, I didn’t notice that at first, it works perfect. I like the ears too.
