Yeah so there you go. That’s my nightmare fuel for the next four or so days…
Anyone got any suggestions as to how to remove it? I’ve already ran it under hot water for a little bit and it seems like it budged a slight bit, but I don’t think that’s got anymore give.
Okaaaaaay, so I’ve had this problem with other pieces with broken axles, and here’s my best advice:
You’re definitely not getting it out of there without potentially damaging the broken axle, so get yourself a pair of very pointy tweezers or a pin. You’re going to want to feel along the sides of the pin for a potential gripping point if the tweezers, or a small gap if the pin.
Tweezers can very slightly grip the sides of the axle and allow for some leverage on pulling out - it will slip 90% of the time so have patience, young one. The pin is much harder and much more time consuming, especially if you want your mata lightstalk to be scratchless.
take another axle piece, put glue on the top (not to much, you dont want the axle to be stuck in there with glue) then push it into into the head. wait a few minutes to dry and the try pulling it out.
Get a small sewing needle and get it hot by the stove. Than stab the broken axle with the needle and wait for it to get cold. Than try to pull the axle with some wiggling .
Oh man oh man oh man oh man… this looks bad…
I would try all the above ideas, though this reminds me of something that happened to me once: I put a mata neck lengthwise between the side of a 2015 gearbox and put short pegs in either side… it still troubles me to this day.
