OK.
Thanks @Ghid
OK.
Thanks @Ghid
Alright, Memphis torso instructions.
Here are the parts you’ll need (any colour will do, I couldn’t find everything in black but it doesn’t really matter):
Start by taking the Ben 10 torso and the four axles.
Place them in the highlighted holes.
Next, take the two Technic beams and attach them on top of each other between the shoulders.
Place both pins in the beams.
Attach the circular piece to the pins.
Build this assembly using a socket and a Glatorian neck.
Attach the socket to the crotch, the neck piece should go over the remaining axle.
Take the other two sockets.
Attach them to the side ball joints and bring them as far towards the torso as they’ll go.
Attach the armour piece on top.
Turn the build over and prepare all six spikes.
Finally, place them into the holes on the spine.
Thank you!
EDIT:
Im trying to make a rahkshi head gal with overly exaggerated features as a joke moc.
i need help, what are some tips for making a moc like this?
She also NEEDS high heels.
NO. EXEPTIONs.
Hey guys, I need some help making custom thighs for my MOCs.
I know that Inika thighs aren’t the most original therefore I need your inputs
Something that i discovered that might improve your mocs if you want to add Organic parts cheaply (Prototype)
Well, it’s been a long time You may or may not know me but if you do so how remember me, I was the person who made the GWP Keetongu moc for the Lewa contest, but you might wonder what I’ve got to present you, well let me explain to you how I made it. So, one day I was trying to make a cape with paper for my Kopaka (G.1+ G.2) moc and well after I took the pictures and edit those pictures, I had a random thought about putting paper into the limbs of my G.1+G.2 toa Mata teams to make them look more lifelike I guess and this might improve Every moc that’s somewhat going for a realistic and robotic look For example here’s the Kopaka pictures:
Well, I hope you people liked this discovery that I found and as well have a good evening, morning, night, etc. I’ll see you later.
Nobody is gonna sting ya for non-purist builds, there are plenty of samples of that around here. I’m sure a mod just shuffled it in here to keep the boards consolidated and organized. Do watch out for double posting, though; if you’d like to say more, there’s an option to edit your previous post and add to it
just another way of keeping the boards consolidated. The paper is crafty, though. Shows there’s more to thinking outside the box than I had realized.
Would be cool to see other more durable materials like felt and leather used on limbs in a similar way
heres how to make and or draw gwp style bionicle masks
step by step explanations
pictures and tutorials
the most easiest way to do it is to draw them yourself first get lego slope pieces as the masks then grab blank paper stickers and markers
then search up some peoples customs or the original masks themselves and then draw away
EDITED FOR DOUBLE POSTING - Spiderus Prime
I’ve been trying to make my first moc for a while, but I always get stuck on designing the body, it either looks too skinny or doesn’t have enough support. does anyone have any tips, builds, or ideas on how I can make a good torso that doesn’t look barren or skinny? just a skeleton frame works but armor ideas would be nice too. this is what i have so far, i just need a way to connect everything. also, any other pieces of general advice would be greatly appreciated!
This thing is already a work of art…
I’d recommend starting with just the hips, choosing either the Metru hips or the Vahki hips as they have a decent amount of connection points. From there, generally you want to have some sort of piece or style for the torso, so scroll through Studio for a bit until you find the piece you want. From there, see where it can connect to the hips and how you can get it in the desired position.
For this MOC, specifically, I think the Vahki hips are better. You can put in a few axles and connectors to get it to connect to that black part in the back, while leaving some axles bare so you can connect maybe a Vorox shell with some Hero Factory armor connected.
You have probably seen this before, I might know how it works given it’s an Alieraah technique. But what parts are exactly used here for the thighs? It’s been a big mystery for almost 4 years now since the post this image came from was on.
Looks like some CCBS parts for the back part and some regular curved slope wedge things for the outside. I think the curved parts under the CCBS shells are part 24201 (Slope, Curved 2 x 1 x 2/3 Inverted).
I mean, it’s not that big of a mystery to me, I recognize every visible piece there
but at the same time I don’t think I need to explain why I feel no compunction about not explaining how it is built
ya know what I’ll play devil’s advocate and do the opposite of ghid
while I don’t know how the CCBS armor is attached I differely know how the whole thing is made thanks to a but @Bionic_Pyro form discord
not sure how that version is design especially the butt but ya get the just of it
While what you’ve got pictured here is similar to that original image, it’s far from exact. Most notably, the knee sockets are located much further up on the original, and I believe some of the specific part placements may be crucial to how the shoulder pad is connected.
This is certainly a good start though. I’ll see what I can figure out myself
So, aside from parts count and aesthetic, is there a reason to use two 41677 instead of one 45590?
(I’m working with black pieces, so color is not a problem)
45590 is made entirely out of an extremely soft rubber and would not hold any weight at all
It’s designed primarily for acting as a buffer or providing grip, not structural purposes
Anyone got a custom head that looks like my pfp?
For a selfmoc.
Why not just use a dragon head? Or better yet, reference htyd Mocs, such as a toothless moc and such.
You could use this one on shape ways. Bionicle Night Fury Head (V5MYYZWEJ) by PunkDrunk182
