Compatibility reasons, such as being able to wear the MoC and a Akaku Nuva as opposed to having to swap heads.
Uh.
Well.
No I don’t have the design.
Also that only accounts for Mata and Okoto. What about Metru?
What about it?
Your idea of swapping between Akaku Nuva and the Mask of Creation only accounts for two of your requested mask types.
You’ll need separate skulls, but make sure they’re both 2 modules wide.
One skull has to have a connector axle hole, whereas the other has to have the connector pin hole.
Got that?
@Pirean_Grammaticul English please? /s, but seriously, don’t know what you mean.
@Ekorak Fine, swapping between Ignika MoC and Akaku Nuva.
Hold on while I make a sketch.
Keravnos: Toa of Cliche Masks
/s
I’ll see what I can do. I’m warmed up for MOCing with my recent WIPs anyway.
I picked those masks because I’ve a got a little legendary mask stand, and the MoC and Ignika are on it. But yeah, thanks!
Not really, maybe an exploded model? I’m pretty good with those.
Hold on, buddy.
Take your time, man. I’m patient!
@ToaKeravnos
Each skull has to be the same width as a Brain Attack head,
one skull with a + hole,
one with a O hole.
You need a head the you can switch the mouth so you can use and + or a pin
@Pirean_Grammaticul Got that model ready yet?
Open socket -1000000 points. JK, this is awesome
At the time I didn’t have any black ball joints to fill up the socket. Thanks, though!
Would it be okay if I posted a tutorial on how to open a piraka brain stalk light and change the battery? Or should I put it somewhere else?
I don’t know if this is the right place myself, but I would love to see that video.
