I didn’t understand anything you said but the part where you say that I should remove the collar
I have a thick, yet sleak upper arm design is anyone’s interested.
I think that he’s refering to the av matoran limbs around the head. I think it looks fine imo. The skirt looks too bulky though
@tak210 sure
It doesn’t look that bulky when you have it in person
I’d like to see it, if you wouldn’t mind too terribly
aaay, that’s pretty neat
i do. may do a how to today.
for kahlsa mainly, but. eh. whatever
this is a leg design for TITANS. can stress this enough. this is build to be large as hell. it also has very limited articulation to help with stability. just a small disclaimer.
feet:
(really simple, I know. they work, though)
lower legs
(the next bit is completely optional. while i recommend attaching the ccbs addon, as it covers up the knee, use of the elastic bands is not required.)
(optional over)
lower leg complete.
the upper leg is the most densly packed and part intensive part of this moc. while the lower ones did use 4 ball joints, this just has alot of pieces.
anyway, upper legs.
(thats a cheese slope, by the way. just saying as i think its a little hard to make out)
done. complete. finito.
mandatory “asembly” pic. because apparently everyone on the internet is an idiot who dont understand how legs work. (jk.)
the thing assembled. if it doesn’t look like this, you cocked up due to my awful photos.
point of contention: this is the maximum bend. again, this leg is for titans, where looking cool and stability are key. with that in mind, this is, in my opinion, ok.
fyi, although it goes without saying, you will need to double all of these parts, which makes 8 ball joints used in total. PLEASE KEEP THIS IN MIND!
also, if you use, although this also goes without saying, please credit me. or dont. i dont care.
Cool, is there any way you can add more joints to the hip, since one ball joint seems lacking.
Also, does any body have a design for a torso about the size of a g2 Toa that can hold a minifig, and have the head of the minifig sticking out the top?
legs: probaly. not sure personaly. never tried.
torso: no. sorry mate.
For this, you will require these two parts:
Combine them like this:
Then add a mask a put it on your shelf!
It’s quite simple but also very effective for shelf displays. It’s how I display my painted masks in a very cheap way.
Cool idea, I want to try that.
This is just a cool torso design I wanted to share.
Generally it’s for female Mocs and it definitely worked better with this foot becuase the “wings” cover up a bit more. The technic joint does have to be folded all the way in to make this work though.
You can’t slide these up due to the build of the spine.
Anyone have a method to attach KK helmets to bonkle/HF heads?
Knights kingdom? Maybe a head similar to bionicle 2015 (with half pins on both sides) could work but unfortunately I don’t have a design and my few kk masks I’d have to dig up.
Though with some customization you could cut a 2 long pin and glue it to the inside. That could work.
That was the plan, and I may end up going with it. However, you just gave me a great idea…
Edit: My plan failed and I broke a metru head.
try putting a flexible tire of it
So, I found a method to lock the new brain-stalk, only problem with it is that there is a teeny tiny gap in the eyes thats only noticeable at a certain angle
http://i.imgur.com/EQsqMnB.jpg
I may upload a how-to on either Destrucus’ or Adams WIP legs later on.
