These are fantastic, I wish I had those kanohi tho.
(Thats what bricklinks for I guess.)
Actually none of these shown are from Bricklink. But I bought last month 10 kanohi masks for my new comic series since I had not enough.
All these matoran look cool and have their merits
I mean the metrutoran have no eyes but that’s alright.
I need help with the darn arms for this lassy…I went over 15 designs yet none fit…I would be really grateful for any help offered…any bright idea?
Stare into their soulless eyes and know fear.
Or just see whatever is behind them.
That’s supposed to be female, right? That’s what you meant by “lassy”?
Lassy- Lass
Laddy-Lad
As for your question, yes, it is indeed a female MOC.
Honestly, I think it’s difficult to come up with a good arm design for a slim MOC with human proportions.
Don’t get me wrong, your MOC doesn’t look bad, but perhaps it would help to shorten the legs so you can make the arms shorter (long arms tend to look spindly) and/or make the torso broader which would allow the arms to be build thicker without them looking too thick.
EDIT:
So, since I’ve been asked about it, here are the “instructions” for my Okotian custom torso, which I used on my Harvali MOC:
Part list (a bit colourful, because I just took what I had at hand - but it should also help in making things out):
Hips: balljoints with a through axle hole should hold better, but I’m fully out of those. And you would see the axle on the outside if you use them.
Upper torso:
Front:
Back:
These Turaga hand parts just barely fit there and I can’t guarantee, that they won’t bend a little over time. I added them because otherwise I felt like the neck would appear too long - they’re not necessary to hold everything together.
And the finished thing from the front and from the back:
When you add a CCBS shell to the front it also doesn’t fit perfectly, but it should hold.
I hope all of this is building instruction enough. If not - just ask!
Thank you maybe next time can show me how to build the spear, bag, and the lantern?
Oh and the dagger as well.
Edited for Double Post - Waj
Everything but the bag looks pretty straightforward and simple. Shouldn’t be too hard to build with just pictures.
so my self moc is almost done…
it has two forms…
but i need to make a custom cape…
+9,001 hours
Step one: choose a material.
Step two: cut out the desired length.
Step three: apply to MOC.
Step four: ???
Step five: profit.
Step four: make sure it fits with the moc
HOLY S*** HE HAS DONE A RWBY!
Yes… I already noticed that…
I seek help in building one of those pelvis which use a 3-lenght CCBS shell on the front. Does anybody have a little tutorial on how to make it?
So I don’t normally ask for help when building mocs, but well running into a bit of a wall here. Does anyone have a good head design for the original Knights Kingdom Helmets/Visors, particularly the Original Vladek visor?
Here’s one I have been using. Only uses 2 parts and attaches like a normal mask.
Wouldn’t work for the others, though.
