“if any one can build it give me some feed back
am shure thers an imposible conction
and tell me if the gearfunction works
and is there any rare or retierd parts
the arms and legs are supost to be the new pieces from the evo sets”
thank you
I don’t think the shoulders work; the brown 3 axle is only in the bushing by half a stud, and the ball-axle in the shoulder collides with it as well. You could slide it out to avoid the collision, but you’d still have the issue of each piece not being in the bushing by very much.
Could you somehow narrow the shoulders by 1 stud on each side to make room for the standard 2L axle connector?
Seems like you’re off to a good start. Maybe put something else into the gear function as a means of stabilizing the function and maybe use the newer ball and socket joints on the hips and knees.
hey you re here to
i didn t met to pose your work as mine
i realy like how you did yours it was a big insperation and used it as a referance
if you want to be cridited no problem
