I need help deciding tuyet's colour scheme
Hello there, long time no see, so I’ve been a little bit disconnected, since the contest have ended I had no real reason to post anything, but now that duckbricks is making these fanon contest I have found some new inspiration and I intend in entering the Tuyet contest with an art piece. So here is the thing, I am trying to decide on a colour scheme for tuyet and I need help before I can finish the drawing, so here are the candidate:
From left to right we’ll call them number 1,2,3,4,5,6.
  1. Bright blue armour, and sand blue body.
  2. Dark blue armour, and bright blue body.
  3. Dark blue armour, and dark blue and black body.
  4. Sand blue armour, and dark blue body.
  5. Bright blue armour, and dark blue body.
  6. Gun metal grey armour, and dark blue and black body.
I’m looking forward on reading your suggestions.
I’d go with 1 and 4. Both have a color light enough to avoid blending with dark shadows which is a problem I run into sometimes. Plus, 4 looks pretty nice.
All of them look quite nice, but 3 has the advantage of being the most purist, assuming that the build you’ve drawn is finalized
I like the sand blue, but that’s a rather difficult color to moc with, but you should definitely use dark blue.
I personally struggle seeing Tuyet as being a brighter blue. Looks too friendly.
My favorite here is 3. The black and dark blue could work for a standard Toa Tuyet. It could also work well for her more insidious appearances. It’s versatile.
6 is also nice. Same color blocking as Lhikan, still morally ambiguous.
I like number 3 but i feel like its too “normal”, I mean its just 2 colours, also I feel like most people imagine tuyet being dark, but IDK I also like 4 and 5 a lot xD they feel a little more original. But if I end up going with them people would not vote for them because I assume they would want to build tuyet themselves and sand blue like rukah said is kinda hard to work with. I am loving this input guys keep it going xD
3 would most likely be the best
I’m not going to comment on color since I’m running a tuyet contest of my own on the boards, but that broadsword looks a lot like a fish skeleton.
exactly haha that was the inspiration :smiley:
either 2 or 6
these all look rlly good tho
nice work
I think number 2 could be the best option.
I used the colours of 2 so I guess I will say that you should use it. But sand blue would work too. I feel black isn’t the best choice cause it is not fitting of a Toa-Hero. It is far too dark.
