CUE BIG BLUE FROM THE F-ZERO SOUNDTRACK!
“Who’s gonna save the day? This guy right here!”
Imber with his sister Ignis.
Alright then, time for some info. From Tumblr Meet Imber, Master of Water. Imber is the brother... - ChaoticTempleKnight's Bonkles
"Imber is the brother of Ignis, master of fire who serves on the team of Terrus, Master of Shadow. Imber is a relatively new member of the team and certainly shows it. He’s brash, headstrong (much like his sister), and a tad arrogant. But at the end of the day, he is loyal to his team and knows when to stop goofing around.
Imber doesn’t have a “weapon.” he uses hand-to-hand combat and his water manipulation. Although he is a bit sloppy in his fighting technique, it’s still effective when it needs to be. Imber has been offered weapons before, but he has refused them saying it would “cramp his style.”
Before he became a member of Terrus’ team, he had always wanted to join a team of Toa. But he wanted to join solely to be apart of a team (in contrast to his sister’s motivations). Imber seems to have a dark secret as indicated by his brash nature. Is he trying to compensate for something from his past? Only time will tell."
I really like how this MOC turned out honestly. I wanted to make a non-skull villain MOC with a skull mask and this MOC was born. Lore wise, the skull mask is a mask of water that looks like a skull mask. Also the lack of armor on the lower arms was a stylistic choice on my part, although I am not against changing it up if need be. Also the Skull warrior ribs were another stylistic choice on me part. Don’t worry, he is not undead. Plus I don’t have any normal blue torso armor at the moment.
And for the sake of ease and because I have improved the MOCs I mentioned, here is a link to the Tumblr posts about:
Ignis, Master of Fire - This is Ignis, Master of Fire. Info from DA: “This... - ChaoticTempleKnight's Bonkles
Terrus, Master of Shadow - This is Terrus, Master of Shadow. Info from DA:... - ChaoticTempleKnight's Bonkles
So as per usual, tell me what you guys think.
–UPDATE 1–
Eyyy…I changed some stuff around. Tell me what you guys think. Remember, I can always switch it back:
Do you guys thinks this makes more sense? He does use water manipulation in battle and I feel the azure shells give off that water combat vibe.
