This MOC won 1st place in @Vicroen’s Inika Build Challenge, so I figured I’d make a topic for it.
Species: Toa
Element: Air
Mask: Tryna
Tools: Hurricane Glaive, Air Claw, Shadow Cannon.
Combat Stance
As a Matoran, Kudika enjoyed tinkering with and modifying things. So when he became a Toa, he decided to give himself more beastlike attributes to suit the jungle environment of Le-Wahi, these being his Piraka feet; the claw on his left hand as a secondary Toa tool; and a pair of insectoid wings on his back.
His Hurricane Glaive, in addition to channeling his power over air, is able to absorb air from the environment through the butt of the staff and release it through the blades at increased velocities and pressures - ranging from the hurricanes for which it is named to sharp blasts of wind able to cut through solid objects.
Back View
Front View
These wings are used to make himself appear larger, to discourage hostile Rahi from attacking him.
They can also be used in conjunction with his power over air to allow limited flight.
He also attached his mask to his back with a cable, so that if his mask were to ever be knocked off, he could simply put it back on without fear of losing it.
Something that constantly irked Kudika about his fellow Matoran, Toa and the Turaga was their binary view that darkness was inherently evil. Wishing to prove that darkness can be used for good, he equipped himself with a Shadow Cannon on his left arm. While he can’t fire pure darkness from it, he can channel his power of air through it, which the cannon will then lace with dark elemental energy, and fire it from the cannon.
Though already on thin ice with his fellow Toa due to wearing a Tryna, Kudika is confident he will succeed in his goal.
