it won’t i tried .
But the Pakari is a good change I love it.
This is actually relly good…but I beg the question - do you think it will stand?
it will probably be able to stand
probably.
Because I have a really similar Moc in terms of build (The Overlord) and thanks to his dull legs he is hard to pose around into more interesting poses.
You could use U joints to connect the two gearboxes. I’m not sure if it would work, as there’s no pictures of the gears.
i already connected them, so its whatever at this point
You will also want to make shoulder-pads to cover up the insanely awkward shoulder connection that there will be.
does the pakari looks good?
I think it works fine…it’s odd to me seeing a Makuta without MoCo tho.
What’s the angle? Because if it’s 90 degrees I’d suggest usng two U joints.
when someone says to me “makuta” i think of the species, not teridax or makuta from G2,so in that case every mask can match the term of makuta
its not 90 degrees, thats for sure
I am not gonna do anything to the gearbox, since it works
But we are supposed to make our own version of the reboot Makuta.
No, because this is a contest for the G2 Makuta.
Didn’t I just say it?
I hadn’t seen your reply before I sent mine, sorry.
indeed , but they said mask I should use
or recommended
well i am going to play Arkham knight
Well…go ahead…
I still stand by my word.
M’akuta
