Nikila and Zaria
So a while ago I made this Lesovikk and recently wanted to use this slightly altered Metru build to make two other Toa and probably more. Disappointingly you cannot make these in real life because i’m bad at building lol
Credits to Khingk and Galva for the masks
No one is bad at building you just improve over time and acquisition of parts and you’ve already build them in a program so easy from there you already understand the connection points. The real issue here is you cant build these in real life cause those parts don’t exist in those colors unless you want to spend time 3D printing them, which is costly, or spray painting existing part to match the color.
thats the obvious stuff with coloring and printing but really some of the connections aren’t even possible like they’re just clipping in places that just look good for example a pin-stud piece put into an axle hole and not even centered to it
Cool, i like Nikila’s weapon.
Nice. I like the way the lightning trident is built and I also like the armoring for both of them.
