here is my moc on the assassin Genji from Overwatch
just give a criticism a like and that is all no jokes
Ok, so…the MOC is good, though it needs some slight improvements.
the neck could stand some bulk. Maybe replace that bushing with a gear.
The shoulders should probably be moved down one unit.
The back of the lower legs I think need an Inika armor piece on the back. (Is on the thighs of the original models).
The upper legs could stand some bulk.
But there is one thing that bugs me the most: The CLASHING TEXTURES
Then again, they aren’t horrible, but could use some improvement.
I really like what you’re going for here. I think the designs you’re trying are great, but they could be executed a bit better.
I love that head tho…
really cool but the legs look really squat
The neck is disturbingly skinny, and the feet, well, I really don’t like the feet.
this is a one off moc so there wont be another one im using the body build for another MOC for my Legends of Mythron story
Well its a good moc but the clashing textures especially between the lower legs and torso, the lower arms are pretty good and the torso as well but the upper arms while are nicely bulked do look a little off, not sure how you would fix that but yea, good look though.
alright I see this is a one off
but If you ever return to it
the arms need to be a bit thinner (and lower the shoulders)
also try and utilise some translucent pieces when doing the head
I shall also leave a Photo here so you can see what else you can improve on if you ever return to it
He looks way too bulky
The head is really neat tho
;_;
Not good, to gibbled where it shouldnt be, not curvy enough where it should be.
Needs more work.
You could make the neck thicker, get rid of the random white, beef up the legs a little and fix the feet, like make them a bit thicker because they’re REALLY thin and small.
I just feel like he has too much bulk. It makes him a little messy.
But I do like some of the ideas here.
becaues the image i used shows him with small feet which was gameplay footage
The picture that @Whaddon used has him with bigger feet than this, but then again I haven’t played Overwatch so idk.
whaddon used fan art picture
why would he use fanart to prove a point.
cause there is only fanart when you search genji
I see a lot of gameplay and official art, but there is fanart.
I think the one Whaddon posted is legit.
That’s the original picture for Genji. Every hero has them. It’s like a lower quality picture of each hero, look.
well i found it on deviant art under a fan art folder
You know people repost official stuff on Deviant Art, right?
