Hi! Since I have a scarsity of green Bionicle parts I wanted to use Stud.io.
I tried importing a pack of Bionicle parts, but despite doing everything as the tutorial said they didn’t show up in the editor. What am I doing wrong?
Are you using a Mac or PC?
For Mac I had to go into the folder where the Studio app is located in my computer, go into the lDraw sub folder, and then paste in the file that was downloaded- in the case of the Biopack it was a folder called CustomParts. I had to change the name of it to Custom Parts (adding in the space between the words) in order for it to work, I was then able to see it as a palette option in studio.
Thank you! It worked!
I’m using a Dell Inspiron 15 5000 Series so there is not working because the computer is incorrect?
No it should work on a dell just fine
Something that confused me for quite a while was that I had trouble locating the “Custom Parts” folder where the tutorials tell you to put the parts files (I had to do it manually 'cause I use a Mac). Eventually I figured out that the folder probably doesn’t exist to begin with unless you first make a custom part or minifigure in Stud.io’s sister app known as “PartDesigner”, available here: https://www.bricklink.com/v3/studio/partdesigner.page
Yeah, or you can always manually create that folder as I eventually did.
Excuse me hello, sorry to bother you but I didn’t want to create a whole new topic to ask something this minor.
here goes. I am trying to use connect tool to connect regular pins to inika torso. for some reason I can’t connect them using the connect tool. I open connect tool, choose the pin and it shows small cylinders inside it, choose one of them but when i try to click the bionicle torso it does not regognice my command.
i tried to connect regular pieces and regular bionicle hands and legs, they worked marvelously.
is it impossible to combine pins and torso using stud.io?
Try just dragging it instead of using the connect tool. It should snap into place.
Welp, now I have a question about Stud.io:
When using it, how do you bend flexible elements like chains, hoses, and flex tubes?
With extreme difficulty. I recommend this channel; while I can’t listen to his cadence, he’s very knowledgeable about the software and makes instructive tutorials.
It didn’t snap into place but I found out that instead of clokcing cylindes at the end of pin I could select one in the middle. Thank you anyway.
I was prepared to post a thank you message like this one “now I know how other scientists felt when they saw E=mc^2. It was so simple”
I’m on Windows and can’t figure it out
