Howdy all,
Here’s a MOC project I’ve been working on for a few months now.
My focus was to create a firearm system using Technic that would be scalable. Due to my lack of pieces, I settled on some Protector style MOCs that I had floating around.
The Base system is an axle (size depends on what you’re trying to make. Pistol: 3-4, Submachine gun: 5-8, Rifle/Assault Rifle: 6-9, Sniper Rifle: as long as you want/have) with Cross blocks and split cross blocks along it. Axle Bush connectors are used for grips.
The Base Rifle
The Base Pistol
For addon’s:
The base grip for long-guns resembles a semi-pistol grip but by using a connector and bohrok eye, we can make a stock (works well for protector type builds but using axle.pin.pin blocks will work for larger builds)
Using one or two connectors will give you a good suppressor (silencer for you non-enthusiasts) or muzzle brake.
Using axle pin beams you can make lasers,
flashlights
or optics depending on where you put it and what you put into the pin-hole. (although you can combine any of these add-on’s using your imagination)
You can also use a Bush W/Connecting Piece as a holster/backstrap.
This system is expandable. (I just don’t have the pieces) and I would love to know what any of you have for suggestions to expand it with. Here’s my collection so far:
Collection so far (sorry for bad quality)
Good MOCing all.
