Are the ball joints in the waist (where the pistons were) connected to anything?
No, they just fill the gaps in the sockets.
Readjusted the shoulder connections. Works quite well now, I think and doesn’t look too bad. Probably need something to fill in the gap below the pauldrons a bit more, though. Maybe even more cables/hoses.
Still no idea what to do about the back, however…
Lower arms will also be a bit challenging to keep elbow poseability.
Some demonstration of the arm poseability.
Lower arms and finally a complete back for the torso. Rearranged teh cables/hoses a bit as well. I think I now have every single one of my spare Zamor launcher cables in here…
Before tackling the head, I guess it might be time to get replacement parts to switch out some of the black. Also I need parts for articulated fingers. And maybe there’s also some interesting stuff to be had for building the head around.
So, first order of replacement parts/generally some resources in dark grey came in, so I got started on the head for Fenerak. Also got a few recoulours for Isthra, but there’s still stuff missing there as well.
Got started on Fenerak’s head, though. And I think this kinda fits? It’s really just the front at this point, however. Back/sides still need some work.
As I’m slowly replacing as much black as I can with dark grey/silver, I do really start to feel like I should maybe add a tertiary colour to him to not make him too bland. Would be red/dark red, I guess. I’m wondering if the sickle pieces in red on the chest would be too much…
Looks good! My only suggestion is that the head might be a little too smooth and round, since both the original and your first version were quite angular. Maybe horns would help break it up a little?
Had the same thought today and already did something about it:
I guess he’s pretty much done now. Just need a few more recolours.
That definitely looks better. How does he look next to Vulon?
Big. But I think I managed to hit the difference where he looks properly imposing while not on an entirely different size scale.
While working on acquiring the replacement parts needed for Isthra and Fenerak, I guess it’s about time I get back to actually covering more Makuta rather than just updating old builds.
I’ve decided that next up is @SteampunkTahu’s Makuta Xiavlak - the Necromancer. Definitely a candidate for a cloak again, too.
So far I have the legs mostly done and started figuring out the torso. I went for digitigrate legs since I like interpreting postures that can’t straighten the legs as digitigrate, plus I think it helps with the size of the foot parts (feet are supposed to be silver, but apparently I only have one right now). I also decided that instead of the orange from the Tridax pod, I might instead go for trans-blue which could fit the necromancer vibe better. Have to see if I can include it a bit more throughout the MOC as well.
So, some progress on Xiavlak:
I think the wings should be attached a little further back. I might also need to see about really adding some more trans light blue throughout the build. I do like how the chest turned out so far, but it does stick out quite a bit.
The top of the torso will otherwise be the next challenge. Especially since the neck needs to face forward with a ball socket to attach the Metru head, but due to the chest construction where I can’t connect anything on top, I have to actually build an extension from the back first. A friction socket with the straight axle connector is probably my best bet, but I try to avoid using them more than absolutely necessary as they are quite difficult to replenish from bricklink as I’m not willing to spend more than 20-30 cents on one, which is already kinda crazy for one part. I might perhaps have some slightly damaged ones that won’t work as friction joints anymore anyways, but would do for a neck, though…
The dark blue seems much more prominent than the original. The original feelf like it’s primarily silver with blue undertone on the limbs, while this feels primarily blue with some silver armor in a few places.
Honestly, the original doesn’t have enough of any given color to have it clearly stand out, as black, blue, and silver are all fighting for primary status. I think silver feet are definitely the way to go, though, so enough of the silver in the original is present here.
Also make sure you have it also violently dismember Stars Takanuva for authenticity ![]()
I am considering switching some of the black liftarms on the upper legs out for light gray ones. Those might fit in with the silver well enough and mimic the original a bit more (which also uses light gray ones, for that matter).
Well, I don’t have any of those pinhole/ extended axle parts (yet), but something like that, yeah. With the straight axle connector of the friction socket, connecting it shouldn’t be an issue. The issue is more if I wanted to use a non-friction socket which does not have the straight axle connector. So I guess it’ll have to be a friction socket.
Not neck-essarily. You can use this solution as an alternative, which unfortunately moves the neck one unit up.
It uses a normal socket, with the liftarms stabilizing the pin connection and preventing wobbling. This build should also be buildable in light bluish gray!
Hm… maybe actually attaching the neck one unit further up is indeed an option. That might just still work with the look if I can do the shoulders/upper arms right.
