Are there any parts packs for the Lego Knights Kingdom...Bricklink Studio
You don’t need an installer.
If you open the file in Google drive and click the download button in the top right corner, then you will be able to open it in the Studio app.
I did and it didn’t work. Sheesh I feel like i’m talking in circles.
Still no progress
Your computer won’t let you download a file from Google Drive? It should just show up in your Downloads folder, and then you’ll have to manually extract the custom parts with a program like 7zip.
What are you installing here? A parts pack, or the Hagah file?
I’m just looking for a pack that includes the armor pieces needed. Here is the parts pack when i try to install it correctly…i also attempted inside the parts folder
But it interferes with many bricks and the disappear the red outline indicates the text that appears. Even the Retired Parts and Buildable Figure category disappear. So i have removed it AGAIN
Have you tried manually dragging the files from the parts pack to their respective folders?
Looks like the pack only had the models because of they are model files if they are in the downloads. They can be opened, but once there
  • Manually copy the pieces with Ctrl + C
  • Close the knights file and paste the pieces with ctrl + v them in the other file you plane to use
Other wise studio will have a missing bricks like i told you about. The Knights Axes torsos and most parts work But the heads have no faces, no helmets, no shields and no swords The swords were the most important pieces.
If you check out the Google Drive link for the DCC, it contains model files of the Toa Hagah (which contain at least some of the swords):
It would probably also be worth checking out the Knights Kingdom models.
Also, if you’re interested, there’s a method for extracting the part files from the model file to move them into your Custom Parts folder, but you’ll need the free program 7zip. Just open the .io file with 7zip, and it will open a bunch of folders with the custom parts, which you can just copy to your own folders.
Those are the same knights kingdom models in the folder i downloaded. I’m downloading the Bionicle gen 1 model pack from your link. hopefully the knights kingdoms weapons are in there and will work.
EDIT: The file worked
