you can use this for a function where the heads fly off when a model is hit, like one of the functions planned before they changed it to masks flying off because lego thought decapitation was too brutal
Gove em some Tarakava arms and then suddenely you’ve made rockem sockem robots
That would be really cool to see
My main thought was just use the axle point to attach to a torso, but I guess launching head finishers would be a pretty obvious and fun use lol.
Though my launchers vary a lot in power atm, some produce rokem sokem long necks and some go flying. (probably from leaving ammo in some of them weakening the spring)
Hey does anyone have a big torso design that i could use?
Need help on making a Chibi sized frame for my self Moc, syrax. any ideas?
Need a big thigh design.Anyone have one?
What scale in this case?
Vortixx sized.
Which pieces did you use for the sides of the spear tip? It’s a pretty clever build.
Tis a 3-year old post, you’re aren’t likely to get a response. However, the piece is a claw that came with many Hero Factory sets, I’m sure someone here will be able to find the piece number.
Pls i have very limited parts and need a big thigh design for a vortixx that i can use.
It’s difficult to help when we don’t know which pieces you have. Is there any particular armor piece you want to use? Sometimes it’s best to select a few pieces and build around them
rahkshi shells,liftarms,and cbs shells.No liftarm with fan pieces.
it might work…
this thingy if I’m wrong
just added some 2 small Axe Liftarms and Hinges for the pointy things. hope that helps
(also sorry I have been gone for a long while. stuff happened here and in that time I needed a beak)
I happened to be building a bit tonight and tried a variation of this design out–it regrettably doesn’t work. The piece to which the Rahkshi shell is attached physically prevents it from folding down as far as the picture shows.
It’d move it down one but could work
I was talking about this blade, but thank you anyway. I already found it, its number is 92218 in case anyone else is looking for it.
