Anyone got a decent scythe design I can use.on my MOC
@DG_Eddie cheers
@DG_Eddie cheers
Dave on deviantArt has one, just give credit. Bionicle MOC: O-jin by Matteo-T-I-F on DeviantArt
That is one cool Meso.
I am in need of some large but stable leg designs has anyone got any suggestions?
I would like to know how to build a tonfa from the star wars movie(the one that the stomtrooper fights Finn with) if anyone has any disigns that would be greatly appreciated.
**Disclaimer: My explanation is very confusing**
I have an idea but just don’t know how to show you (But this would only be an extended version, and not the storage version). You can probably use the Lewa Uniter tonfa (get rid of the blades), the where the blade was, put an axle (you find out how long it will have to be), then use these to cover up the axle. Then, connect this
to the end of the axle, push a 3 length axle through that, then connect a technic axle connector to the ends of the axle. Finally connect a 3 length axle to both connectors, use the 1st piece I showed you to cover up the axles (but keep space on the axles), then add these with Barraki eyes at the ends.
Here you go: designs for both the weapon and the shield.
Does anyone have a design for lower legs using the hero factory 1.0 shin guard?
That frame by itself looks awesome.
I couldn’t find a topic like this, so I decided to make one. If it already exists, feel free to delete this.
I thought it would be nice if there was a place for everyone to share custom torso designs that they either had designed but had no use for, or that they simply wanted to share with the LEGO community. I’ll start things off:
<img src="/uploads/db5640/original/3X/f/6/f611a8e89f50be415088c3c80e80a5007cccb7be.jpg" width="160This torso was built for extra arm articulation, allowing for the shoulders to move forward and back.
Here’s the torso used on my Makuta 2016 MOC.
And here’s a large torso which I threw together a few months back to incorporate all the gearboxes I had at the time.
If any of these look amateur, it’s because they are. I’m still learning about building custom torsos, so hopefully this topic will help out anyone in the same position as me.
My favourite custom torso is where I’ll take two Metru hips, and connect them by pins, and then use a Hordika neck as an actual neck. Often, I’ll add on the Metru gearbox cover thing in order to bulk it up.
Your torsos seem pretty well done.
Very sturdy with ten points of articulation.
This thing is cool looking. I built it up, but I think it would be better without the mid-torso articulation.
Is there an example showing how it looks like armored normally?
