So I’m trying to replicate the torso of this character without the shoulder loops, without any success. I tried using 2 Toa Metru chest plates and one of Tahu Stars’ gold armor pieces in order to make that “V” shape the torso has when it tapers at the waist but I keep getting stuck designing a custom skeleton to incorporate such a shape.
Anyways, any tips/building methods would be most welcome.
So in all the years that I’ve been MOCing I never was good at making custom torsos, specifically large ones. Does anyone have any tips? Oh, and I also tend to use Inika lower torsos a lot.
The best way is to take a piece of non-torso armor and all the moving parts (neck, arms, waist and legs), then connect them. Other than that, all you need is practice.
I know that isn’t a lot to go on, but that’s all I can say without micromanaging your build. Good luck!
What about using upper and lower Inika torso parts while also being fairly custom?
@JMP Hey can you send me some close-ups of that figure’s torso from different
angles? I really like it and want to draw some inspiration from it
Double posts are double posts, even if they’re several days apart. Sorry. --John Smith
Inserted @ mention. @Sevrix_the_Hybrid, if you wanna reply to something new without double posting, simply edit your previous post and tag the person you’re replying to either by quoting them or @ing 'em. -legomaster #DoubleModEdit
I’ve started to get into making MOCs, but I have an issue with the CCBS torsos, the shoulders.
Is there a piece that has the shoulders of this, but is the same height as the bigger torso piece that I can’t find a picture of.
