I’m quite proud of this. The torso is completely custom and so are the lower legs.
Here’s a better look at the torso construction.
Constructive criticism is welcome!
It’s gud. Really gud. I like the custom torso.
the blue pins fit with the color scheme
Looks good!
I like it Coolio.
Very nice just not sure about all the colours of blue on there apart from that pretty good.
I only used the trans-blue shells on the arms because I didn’t have what I needed. The colors blend in person, anyways.
Ok now that I know that I can understand the colours.
(I’m embarrassed of my MOCs now)
Thanks a lot man!!!
Well, I just learn from other MOCs. This is the only time I’ve made a torso completely built from scratch.
Mine tend to be custom but built around a hero factory 2.0 torso. With my last MOC you barely tell IMO so I was happy with that. For first time custom torso, very impressive. Looks very solid but also decent at the same time, some can look very fragile and flimsy
Thank you!
I’ve built several custom torsos, but I’ve never built one that wasn’t built around an existing torso.
My first attempt did work out very well
Wish I had that mask. I can’t say I like the weapon too much, but everything else is good.
Thanks!
What’s ironic is that I have had those weapons for a while. I really liked them but had no blue MOCs before this.
I’d recommend increasing the amount of mata blue.
The Nuva boobs are slightly out of proportion, but they aren’t too bad. Color distribution may have been better, but since you have a parts restraint, it’s fine.
I totes wish I had that mask.
If I can find the piece used on the lower arms in Mata blue instead of Metru blue, then I will change it. Same thing with the upper arm armor. I just don’t have enough blue CCBS.
This was actually going to be a Gali Nuva revamp, which is why the torso armor is sort of emulating the Nuva torso piece.
Nice moc, @JoeScibelli.
Covering the Unity armor holes would be nice, good build.
Nuva armor on the chest that does not look freakish.
10/10
