One question has been asked since 2002/2003 with almost notorious frequency: How much more powerful are the Toa Nuva compared to regular Toa? Today the question will finally be answered after 20 years…
After their transformation via energized protodermis the Toa Mata, now Toa Nuva, are said to (among other things) possess greater inherent elemental power and control than any other Toa. But what does this mean exactly? How much is “more”? And how do they compare to other elementally powered beings?
For one, we know few basic things: 1) Nova blasts of Toa Nuva now have even greater potential than before, drawing on bigger elemental reserve, 2) Nuva are capable of starting a process utilizing elemental energy in advance and setting a timer on it - something normal Toa can’t do.
That’s great and all, but we already knew this. The real question is how much grander in terms of numbers is the elemental potency of Toa Nuva? Concrete information is few and far between even in Greg’s answers - the reason being it was intentionally left ambiguous. But, the hard work researching proved fruitful - among many quotes simply expressing uncertainty, or refusal to elaborate, two are good enough and sufficient to work this out definitively:
Q1: What is the extent of a Turaga’s elemental powers? Hypothetically: 3a) Could Turaga Whenua use his drill staff on the ground, gather the surrounding soil and thrust it at an opponent? 3b) Could Turaga Onewa slam his stone hammer on the ground and make a stone dart up and hit an opponent? 3c) Could Turaga Vakama use his fire staff to gather surrounding heat and make a fireball to launch at an opponent? 3d) Could Turaga Matau use the buzz saw on his kau kau staff to whip up a breeze strong enough to knock an opponent off balance? 3e) Could Turaga Nokama use her trident to gather surrounding moisture and force it at an opponent as a tidal splash? 3f) Could Turaga Nuju use his ice pick to create and launch icicles?
A1: The quick and dirty answer to this is that if Tahu’s can create a firestorm, Vakama can light a torch. Take what a Toa can do, divide it by about 500, and you have a Turaga’s level of power.
Q2: On a scale of 1-10, 10 being a Toa Nuva and 1 being a matoran, how would you rate the elemental abilities of turaga and general toa? (Use decimals if you want)
A2: A normal Toa would be a 9, probably – and a Turaga would be more like a 3.
Ok, so we get a scale with four data points. We also know that value 9 is 500X bigger than value 3.
Those two are 6 tiers of power appart. What we need to do now is to find out the multiplier between the neighboring tiers (one appart). This is fairly easy, since we know 500X represents six shifts in power, a single shift needs to be:
Toa Nuva are a single tier above normal Toa, which means they are 2.82 times more powerful in terms of elemental energy. This seems quite reasonable and even coincides with the vague increase most people already imagined.
But some observant individuals might notice I made an assumption in this calculation. How do I know the multiplier between tiers rises exponentially? What if the differences between tiers are additive instead of multiplicative and the total difference between 3 and 9 just happens to also result in 500X increase?
Well, there is very strong evidence out there that the elemental potential does indeed rise exponentially. We have one instance when a character gains multiple tiers of extra elemental power in real time and we are given added details. It is the scene in Many Deaths of Toa Tuyet when Tuyet finally taps into the power of the Nui Stone, resulting in massive increase of elemental power:
„ Her hand closed on the stone. It began to crackle, a nimbus of crimson energy surrounding her. Lhikan hurled a fire bolt, but she deflected it without even looking at him. Her power was already growing exponentially with each passing moment. In a matter of seconds, she would be able to snuff him out like a tiny flame in a windstorm.“
This prooved the assumption for me and I could proceed with the calculation as described.
We can use this information of 2.82X multiplier further. If we were to extend the scale beyond 10, where would the Tuyet from Reign of Shadows, said to be 200-300 times stronger than normal Toa place? If we take the 300X difference between this Tuyet and rank 9, we would find out that the corresponding rank is 14.5. This agrees with the notion that Tuyet with Nui Stone is much stronger than even a Toa Nuva. We also know that she is even more powerful than a Makuta (elementally), so a Brotherhood member would need to be somewhere between 10 and 14.5 on the scale.
So that is it, the 20 year old question is finally answered in a satisfying and concrete way: A Toa Nuva has 2.82 times more powerful elemental ability than a regular Toa.
