I just have bought a Kopaka a couple of weeks ago, and for some reason, his right spear arm keeps falling, even though I built it right.
I went on YouTube and saw Jangbrick’s video on Kopaka, and he managed to extend his Kopaka’s arm completely without it falling.
I need advice on how to make the right arm stronger.
If I discover anything, I’ll help those who ask.
Some other people have had this problem; I believe one of the molding machines made the holes in the gearbox slightly too large, so there is not enough friction between the blue pin and the gearbox. I would suggest ordering a new piece, or using something to increase the friction. There are some solutions you can find online for more friction. (I’ve heard that Pledge floor cleaner works, also clay.)
I have no clue what Jangbricks does to get the gears like that, or if a LEGO sends him special pieces, but on all of my Toa (minus Onua) the arms will fall down unless the elbows are closer to a 90 degree angle.
As I said, I believe that some of the molding machines for the gearboxes were messed up and made the peg holes slightly larger that they should have been, which is causing this problem. You could either order a new gearbox piece or find something to increase the friction.
Actually, I managed to fix it.
I switched my Lewa’s gearbox with my Kopaka’s gear box. It seemed pretty effective.
Of course, (if you have the same problem) it may vary.
I switched Kopaka’s with Lewa’s because Lewa had more friction on his, while Kopaka had less.
It seems to work (not perfectly, but much better).
Lewa almost works better than before.
Are you europian?
Because I have a same problem on ALL of my Toa. It seems like there is not enough friction on shoulder ball joints, e.g. Gali’s arm with trident always falls down without even moving the gear on her back. Like the ball piece was not that large as normal ball joints…
Go to lego.com, scroll down to the bottom of the home page and look for Customer Service, and click on Missing Parts. Select the set, then the piece, and they’ll send you a replacement. Or you could just call Lego customer service over the phone.
For the double posting, you click the pencil in the bottom right hand corner of your post to edit it. Delete one post and copy the text over. Tag the person’s name who you meant to reply to in the second post, by adding an @ in front of their name.
Read the rules and regulations. Also, it has been fixed for you by @WajKnight.
