Some pictures of how to fix Lewa’s gearbox and with the swords on his back may be nice.
I was looking at Lewa’s reviews (in this case, someone’s opinion of his cons when I found this…
Gear box is placed… interestingly. It looks cool on him, like a large backpack, but the side effect is that his head is hardly able to move.
-But this can be simply solved by taking the silver spike (the one covering some of his back) and placing the large black peg right below the smaller black peg, then adjusting the whole gearbox down one space. His head then can be able to move a bit more, but still barely is able to look up, which is very important on the gliding feature.
While it may not solve the whole swords-on-his-back-thing, it seems to help.
No, I don’t mind.
At first, it was like turning a key in a car ignition…kind of hard at first, but eventually it got smooth.
I eventually managed to loosen it.
But overall, it is an awesome system.
Moving on, how does one revamp the Lord of Skull Spiders to make him a bit more taller, and flexible in the legs?
OK.
Does the arm fall because of the black ball (see instructions step #6) it is attached to?
Or is it stuck tight? You can figure this out by taking Tahu’s arm out of the gearbox, and swinging it around. If it’s like the first, try attaching Tahu’s arm to the other black ball one next to it.
