Name: Trenton “sky knight” Rider
Appearance:
Bio: Rider was part of a scrapped project to create a team of heroes designed for arial combat. As the first to come out of this project, Rider was deemed too costly for not needing to be used in many situations. Adding to this, a jet pack design usable by all heroes was being worked on when Rider was built (this is the jet pack seen in set #44014). Rider was made to be paired with a jet pack/drone that is specifically designed to operate based on electronic signals sent from riders body.
Rider is built with lighter armor than most heroes to help with air maneuverability and overall weight, but with lighter armor comes decreased durability. To attempt to counter this, Rider has a internal repair system. This system helps against accumulation of damage, but cannot keep up with accumulation over a relatively short period of time, this also leaves Rider venerable to large attacks.
Weapons: sword, hero cuffs, and a electromagnetic bolt gun on the drone.
Personality: Rider tends to be quiet, but is also a bit impulsive, and frequently has his head in the clouds (both literally and figuratively). He also views his drone like a pet, as it can act independently of Rider.
This is the first and only HF moc I’ve made to date, so I hope I did well. Also, I don’t know much about the HF cannon, but I believe this is consistent with the cannon through breakout (at least with what I remember). As always, comments, criticism, sarcastic remarks, or all of the above are welcome.
