Here’s a simple eye design that uses clip fingers to represent sclera.
and cut tube ![]()
Does anyone know a way to give a toa Hagah function more friction?
I found way to give a little bit of friction, but even with it they can’t hold any heavy weapons.
thanks, that one has a sufficient amount of friction (I already had the voodoo ball in, but didn’t think of adding that grey piece at the bottom)
(If anyone has a design with even more friction though, do share!)
bruh that’s literally how the piece is supposed to be used
Funny you should mention that, I’m actually working on it right now. I’ll post it here as soon as it’s done.
Purists could use a stamper tile or a small horn or the 1x1 round plate with a 3.18 bar on the side. 1x1 round plate with a 3.18 bar on the side would theoretically be most effective since the round plate can be buried by other parts.
wait that actually worked
Yep. And I don’t think is strains the pieces, so that’s nice.
well the image link said it was from reddit so i wouldn’t put too much trust in it
This is the solution I came up with (picture focus is a mess, but should be visible enough). The pin in front goes through the intended front plate for the Hagah torso, and then a Gahlok Kal shield piece on the front for added friction (any Bohrok shield with a centered pinhole will work for this).
boi you stealing my thunder
That’s another good one, but I’d rather not use a bohrok shield. The character I want to build uses a modifyed Hagah build, but isn’t actually one of the hagah.
But who knows, I might change my mind and put in a Gahlok kal shield.
if you aren’t opposed to temporarily modifying your parts, a small, dried dab of hot glue does the trick on the axle that goes into the chest
THEY LIVE
unfortunately, I am opposed. Im planning on submitting this to one of the canon contests later.
Hey that’s mine!
Works like a charm btw
I do have a method or two. I can get pictures sometime soon-ish
Scrolled back a while to see what convos I’d been missing, so this is a bit of a necro, but you might actually be fine with a standard-sized head for that body. It would match hero proportions fairly well:
I looked into these proportions a little while back when making a body for my krana-sized heads, and found that the right body size was a few units taller than the Hero Factory average body:
Mistika Tahu’s mask should be about the right size for those proportions, if you make the neck a bit smaller.
